christer12
Jun 04, 2020Star
New Firmware Released RAX40 1.0.3.80 with WPA3
New frimware is here with finally WPA3 and Smart Connect But what more new?
- Jun 08, 2020New Features and Enhancements:
Supports Smart Connect.
Supports WPA3.
Supports better device identification in the attached device list.
Enhances the boot up time.
Bug Fixes:
Fixes the WiFi driver crash issue
avf0000000000
Jun 12, 2020Tutor
I upgraded the firmware and the router crashes daliy now.. 1.0.3.80 It lookslike an issue with IOS - WLAN access rejected: incorrect security. But not sure... The new features are great but not worth the daily crash. Very disappointed working from home. I tried rolling back the FW and restoring my settings but that did work. I guess I will roll it back and restore factory settings and allow it to populate the access list.. Anyone else having issues with the new FW and it blocking / crashing?
avf0000000000
Jun 13, 2020Tutor
Update if it matters.. I thought I would give the latest FW another try... I reset the 1.0.3.80 to factory reset. Then add all the devices back into security. That was this last night. It blocked a few wireless deviced during the day and then it blocked everything on my network just after midnight casuing me to reset the router to factory again.. I then gave up and rolled the fw back to V1.0.2.60_1.0.1 My hope is the the router is dieing and I will be able to take it back to bestbuy and swap it out, It has been a great router since I got it
