christer12
Jun 04, 2020Star
New Firmware Released RAX40 1.0.3.80 with WPA3
New frimware is here with finally WPA3 and Smart Connect But what more new?
- Jun 08, 2020New Features and Enhancements:
Supports Smart Connect.
Supports WPA3.
Supports better device identification in the attached device list.
Enhances the boot up time.
Bug Fixes:
Fixes the WiFi driver crash issue
ZacharyZSun
Jun 15, 2020Guide
My wifi just stop broadcasting the signal after a few hours, it happened twice today. The lights are both on for 2.4g and 5g but I can't find the wifi on any of my devices
- avf0000000000Jun 15, 2020Tutor
If you can get into your routers GUI. You may find that you devices are being blocked. Mine started with a couple then eventually all were blocked that were on the network. Had to keep trying new devices until I could get in to unblock. I eventuly gave up did a factory reset. I then rolled back to my old FW . Has not crashed since..! Hopfully Netgear is aware of the issue and is doing somthing about it..
- ZacharyZSunJun 15, 2020GuideIt might be! But the older version of 1.0.3 also has a lot of issues. I don’t have access to 1.0.2 firmware. Don’t know where to find it.
- ronald_frJun 16, 2020Luminary
Hello,
my RAX40 has been upgraded to 1.0.3.80 on 12th.
ISSUES :
- Wifi have lost inthernet access after 8 hours >>> power off on
- "Attached Devices" is not reliable as some devices are not there (wired or any WiFi on 2.4 or 5 GHz) or all devices from a WiFi chan
to be continued
Ron
- Christian_RJun 19, 2020NETGEAR Employee Retired
Hi @jrdotmac, The_David, & Retired_Member,
Thank you all for confirming! I'll have the feedback forwarded to the product teams.
Thanks,
Christian
- Retired_MemberJun 19, 2020
Christian_R could you please visit and/or forward the comments from this below thread to the product teams please?
