christer12
Jun 04, 2020Star
New Firmware Released RAX40 1.0.3.80 with WPA3
New frimware is here with finally WPA3 and Smart Connect But what more new?
- Jun 08, 2020New Features and Enhancements:
Supports Smart Connect.
Supports WPA3.
Supports better device identification in the attached device list.
Enhances the boot up time.
Bug Fixes:
Fixes the WiFi driver crash issue
avf0000000000
Jun 15, 2020Tutor
If you can get into your routers GUI. You may find that you devices are being blocked. Mine started with a couple then eventually all were blocked that were on the network. Had to keep trying new devices until I could get in to unblock. I eventuly gave up did a factory reset. I then rolled back to my old FW . Has not crashed since..! Hopfully Netgear is aware of the issue and is doing somthing about it..
ZacharyZSun
Jun 15, 2020Guide
It might be! But the older version of 1.0.3 also has a lot of issues. I don’t have access to 1.0.2 firmware. Don’t know where to find it.
- ronald_frJun 16, 2020Luminary
Hello,
my RAX40 has been upgraded to 1.0.3.80 on 12th.
ISSUES :
- Wifi have lost inthernet access after 8 hours >>> power off on
- "Attached Devices" is not reliable as some devices are not there (wired or any WiFi on 2.4 or 5 GHz) or all devices from a WiFi chan
to be continued
Ron
- jrjdotmacJun 16, 2020Initiate
I have the same issues as everyone else. Random connection drops across all devices, I donwgraded the firmware back to v1.0.3.64_1.0.1
- The_DavidJun 16, 2020Initiate
Same problem as others are reporting. The router completely crashes every couple days. No wifi, no wired, no access at all. Reboot and it comes back again for another couple days. The router had some minor quirks before, but this is bad especially with most of being forced to work from home.
I certainly hope Netgear is making this a very high priority to fix.
