christer12
Jun 04, 2020Star
New Firmware Released RAX40 1.0.3.80 with WPA3
New frimware is here with finally WPA3 and Smart Connect But what more new?
- Jun 08, 2020New Features and Enhancements:
Supports Smart Connect.
Supports WPA3.
Supports better device identification in the attached device list.
Enhances the boot up time.
Bug Fixes:
Fixes the WiFi driver crash issue
Maxgur
Jun 22, 2020Guide
The firmware is not finalized. WIFI connection is interrupted periodically with devices (Smart Connect mode) Problem with connecting Samsung S20 phone. Communication with devices via WIFI may disappear and then the device cannot connect to the router. Only rebooting the router helps, but this is not normal for such a company.
Most likely the firmware is very raw and will fix all problems soon.
