SAM_the_GAM
May 30, 2019Luminary
New firmware released RAX80 1.0.1.58
Manually checked for new firmware and was plesantly suprised there was a new version 1.0.1.58. So far so good!
SAM_the_GAM
Jun 05, 2019Luminary
I discovered some bugs with this firmware I had to roll back to 1.0.1.56
#1 Whenever my cable modem renewed it's DHCP lease it would cause the WAN on the router to disconnect and disconnect my ethernet devices. They do reconnect but you can see the connection time was restarted in the status screen.
#2 Whenever Apple Watch Series 3 GPS/Cellular would connect to the 2G wireless connection the router would reboot.
sui
Jun 05, 2019Tutor
1.0.1.58 is really has bug,I can't enter the router interface after I update it for 1 hour.
To restart, the router can enter the interface first.
