SAM_the_GAM
May 30, 2019Luminary
New firmware released RAX80 1.0.1.58
Manually checked for new firmware and was plesantly suprised there was a new version 1.0.1.58. So far so good!
Christian_R
Jun 25, 2019NETGEAR Employee Retired
Hi SAM_the_GAM,
At this time we do not have a definitive date on the next firmware release. We would still like to work with your directly to help investigate the issues you're experiencing. If interested, please send me a message with your contact info.
~Christian
- amercenJul 04, 2019AspirantI am also having an issue with the RAX80 resetting LAN connections. But mine only occurs when I try joining an Xbox Live Party on my Xbox One X. I researched the issue and it apparently is an issue on some gaming routers, but it does not list the RAX80 as one of the problem routers. The only solution so far is to turn off "Instant-On" mode on the Xbox, but that is inconvenient. I also heard putting a switch between the Xbox and the router should help as well, but I have not tried that yet.
