SAM_the_GAM
Jul 16, 2019Luminary
New Firmware released RAX80 1.0.1.62
Just did a check for new firmware on 7/16/2019 and I was notified 1.0.1.62 was available. I just upgraded. There was no updated release notes - they were the same for upgrading to 1.0.1.58 which is a...
sui
Jul 18, 2019Tutor
The problem still exists, no matter whether it is restarted with 192.168.1.1 or www.routerlogin.net for half an hour, the router cannot be accessed.
Even if you use the mobile app Nighthawk can't access the router. You can access the router first by manually restarting it, but you can't access the router again after half an hour. I don't know what the problem is?
It is normal to downgrade to 1.0.1.56.
- AutomanJul 18, 2019Apprentice
Now has a download page https://kb.netgear.com/000061097/RAX80-Firmware-Version-1-0-1-62
Bug Fixes:
- If the device name on Attached Devices page was changed, rebooting the router restored the device name back to the default name.
- If the router’s GUI language was set to Chinese, the language changed back to English after the configuration file was restored.
- The success page displayed a "Page not found" message if a non-English browser was used.
- Fixes minor bugs.
- Fixes security issues.
My one lets you access the web interface okay but I would like to be able to change the QOS device level Low/Medium/High and also suprised you have to keep refreshing the device page to monitor changing traffic levels. Web interface seems very primitive for such a pricy box.
- suiJul 19, 2019Tutor
Completely inaccessible to the router
- SAM_the_GAMJul 19, 2019Luminary
sui wrote:Completely inaccessible to the router
I have this issue as well with Safari on my iPad and I am able to login to the GUI by refreshing the page.
