SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
baileyj0611
May 29, 2020Tutor
My RAX80 will NOT upgrade to this.
- michaelkenwardMay 30, 2020Guru - Experienced User
I'm afraid that "will NOT upgrade" doesn't help when trying to debug your problem.
What are you doing and what happens when you try?
- Retired_MemberMay 31, 2020
I've been lucky as my RAX80 has been flawless behind an CM1000 modem. Now since the .88 update, I've has constant internet drops. I guess it's my turn now. Doing a factory reset is the only way to get the internet back but it doesn't last long.
- baileyj0611Jun 01, 2020Tutor
When the router tries to perform self update, it states no new firmwares available.
When I try to manually do it, it says the FW file is wrong and will not update.
This router is garbage.
- michaelkenwardJun 01, 2020Guru - Experienced User
This is usually a sign that someone is trying to apply firmware for a different device, that they have got a corrupt download file, or they are trying to upload the whole zipped download rather than the unpacked firmware bit.
Also using it as a network storage host is basically imposisble.
Multiple drive sizes with different fomratting, all lose connection and the router reboots.
- FredAloneForEveJun 01, 2020Star
Update done, every thing works, include my NAS.
