SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
baileyj0611
May 29, 2020Tutor
My RAX80 will NOT upgrade to this.
michaelkenward
May 30, 2020Guru - Experienced User
I'm afraid that "will NOT upgrade" doesn't help when trying to debug your problem.
What are you doing and what happens when you try?
- Retired_MemberMay 31, 2020
I've been lucky as my RAX80 has been flawless behind an CM1000 modem. Now since the .88 update, I've has constant internet drops. I guess it's my turn now. Doing a factory reset is the only way to get the internet back but it doesn't last long.
- baileyj0611Jun 01, 2020Tutor
When the router tries to perform self update, it states no new firmwares available.
When I try to manually do it, it says the FW file is wrong and will not update.
This router is garbage.
- michaelkenwardJun 01, 2020Guru - Experienced User
This is usually a sign that someone is trying to apply firmware for a different device, that they have got a corrupt download file, or they are trying to upload the whole zipped download rather than the unpacked firmware bit.
I am pushing only the chk file, redownloaded twice and tried.
guess i'll keep trying
- NmouneimneJun 01, 2020Apprentice
I think the last firmware that worked with network storage was 1.0.1.64. I had to downgrade to that version, and have not moved off that firmware because it had been the most stable for me.
Where can I find that download? Thanks.
Also using it as a network storage host is basically imposisble.
Multiple drive sizes with different fomratting, all lose connection and the router reboots.
- FredAloneForEveJun 01, 2020Star
Update done, every thing works, include my NAS.
did you have to use TFTP? I'm going to give TFTP a go, since I can't do it any other way.
- bayarndJun 08, 2020Star
Netgear Support updated my AX8/RAX75 to the new .88 firmware because we had several malfunctions on my router with the .76 release.
After 2 hours of remote screen sharing, updating, resetting, testing, uploading screenshots and logfiles, the 2nd tier support technician had run into so many problems, that we downgraded to .64 again. Problems with the new release included total loss of admin connections from iOS devices, frequent loss of admin connection from Windows10 Pcs (both wireless and ethernet), the router not recognizing attached USB devices correctly, Readyshare folders deleted at reboot etc.
/bayarnd
- NmouneimneJun 08, 2020Apprentice
bayarnd wrote:Netgear Support updated my AX8/RAX75 to the new .88 firmware because we had several malfunctions on my router with the .76 release.
/bayarnd
I spoke with a tech this weekend and explained how 1.0.1.64 has been the most stable for me. I also explained how that version of the firmware is missing from the downloads section for the RAX80. Hopefully, they get this straightened out.
