SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
michaelkenward
May 30, 2020Guru - Experienced User
baileyj0611 wrote:
My RAX80 will NOT upgrade to this.
I'm afraid that "will NOT upgrade" doesn't help when trying to debug your problem.
What are you doing and what happens when you try?
Retired_Member
May 31, 2020I've been lucky as my RAX80 has been flawless behind an CM1000 modem. Now since the .88 update, I've has constant internet drops. I guess it's my turn now. Doing a factory reset is the only way to get the internet back but it doesn't last long.
