SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
baileyj0611
Jun 01, 2020Tutor
Also using it as a network storage host is basically imposisble.
Multiple drive sizes with different fomratting, all lose connection and the router reboots.
FredAloneForEve
Jun 01, 2020Star
Update done, every thing works, include my NAS.
- baileyj0611Jun 01, 2020Tutor
did you have to use TFTP? I'm going to give TFTP a go, since I can't do it any other way.
- FredAloneForEveJun 01, 2020Star
no, I have downloaded the zip file, unzipped it and upgrade manually the router in his web page interface
- michaelkenwardJun 01, 2020Guru - Experienced User
Always the best strategy.
No flaky wifi to get in the way, no chance of a broken download.
