SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
magfred
Jun 02, 2020Guide
I forgot to mention that I also did a factory reset after upgrading.
Nmouneimne
Jun 02, 2020Apprentice
When was WPA3 added to the RAX80?
- magfredJun 03, 2020Guide
In the 1.0.3.88 release, even though it isn't listed in the release notes.
- SAM_the_GAMJun 03, 2020Luminary
WAN / LAN disconnections / reconnections are still occuring but not occuring as often like on previous firmware.
- Retired_MemberJun 04, 2020
I have continuous internet drops on.88 and have tried uninstalling an reinstalling it 3 times now with factory reset. The previous firmware to .88 is rock solid for me. One thing I noticed is if you go into the router setup and select advanced, then you page down to the box that shows the 5g status on the right. I use channel 44 but in this box it shows smart connect enabled which has worked for me but then under that is channel and it has a string of strange charters which don't make any sense. Under that is mode it shows 1200 not 4800. I have 4800 set for 5g in wirless settings. Something is corrupt there. This is why my phone keeps asking for the ssid password as I roam through the house. Internet won't stay connected.
