SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
Nmouneimne
Jun 08, 2020Apprentice
pir4tedirk wrote:
I have (only) 27 devices on my network, 4 WiFi 6 and 7 wired.
This release works allows home automation to work blazingly fast and the cooling fan to kick in.
Apart from reformatting USB drives to NTFS, which works perfectly, no special settings to allow it to work really well. Very happy vs previous firmware.
I did can the Armour and Circle options, enabled AX and ODFMA on both radios, WP2&WPA3.
Not being a smartass but maybe full reset and one issue at a time works.
Are you able to transfer large files (3GB or more) to the USBNetword drive?
How are you speeds compared to the last firmware?
pir4tedirk
Jun 08, 2020Tutor
Large number of files large batch no problem, most files around 2-6 Gb from Mac to NVMe 3.1 interface formatted NTFS.
Seriously fast network, fastest ever been on. All devices though this one router, one fast switch for entertainment hub.
