joe_wht
Jun 17, 2020Luminary
New GS116 switch. Plugging it to my New Netgear RAX200 Router makes it Drop ALL INTERNET??
I just bought 2 Netgear GS116 unmanaged switch to replace my 2 antique Netgear 8 port switches. ONLY -1- GS116 arrived today. I'm using this with my New Netgear RAX200 Router & Netgear CM600 Modem....
joe_wht
Jun 18, 2020Luminary
ALL FIXED !!
After Rebooting 1,000 times. Recycling the Modem, Router, Computers, Switches 100 times..
Swaping the ethernet cables from the OLD to New GS116 over & over checking my laptop webpage to see
if for some reason it DID NOT FREEZE...
I FInally decided to hookup -1- single device at a time...
SO I ...
RESET The Router..
Unpluged EVERY DANG THING, modem, router, switches ---
Plugged up the modem... then Router, Then my Laptop so I could see what failed..
I plugged up the NEW GS116 -- and all was good
I turend ON WIFI --- All was good
Then I plugged up -1- item at a time --- All was GOOD !!
-- By Mistake, not thinking about it, I even plugged my 2nd GS116 Switch INTO my 1st GS116
.. I think I have a FREE ethernet cable that's still plugged up.. tomorrow I'll plug it straight into my router.
NOW --- I lost all my " Attached Devices" - Names.. My Sunday, -1- day off from work might me FILLED WITH THAT !!
QUESTION --- On my old routers I would RESERVE the IP Addresses -- on everyting since BACK THEN Netgear had check boxes
to ADD Everything that was not already assigned..
is this a DRAG on the router ??? ... Of course knowing my Printer, NAS, & Desktop IP address is useful, but for some reason I like
knowing everything will always be the same.
Christian_R
Jun 23, 2020NETGEAR Employee Retired
Hi joe_wht,
Thanks for sharing your experience as it may help others!
Christian
