eculuke
Jan 31, 2024Follower
New Internet - Getting 1000 MBP inside of nighthawk RAXE500 but wifi devices testing 75-125mbp
I just switched to a much higher speed internet. When I do the speed test in the app at the router im getting speeds over 1000mbps but when I run tests on any connected device Im not seeing over 120m...
Jan 31, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What devices are you speed testing with?
What do ethernet connected PCs show for speed test results?
How do you have the router configured for wireless configurations? Basic and Advanced?
Any Access Controls, Armor, Smart Parental Controls or Traffic Meter enabled?
What channel configurations are currently set on the router?
FYI:
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.html
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
