dondorn's avatar
dondorn
Apprentice
Aug 01, 2020
New Nighthawk RAX50
I bought a new AX6 Firmware Version V1.0.2.64_2.0.41 to go with my CM1150V Firmware version V2.02.04 figuring it would be the best combo. and work together. I had the Nighthak X6 before this and did...
  • Christian_R's avatar
    Aug 05, 2020
    Hello dondorn,
    If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support.
    https://www.netgear.com/support/default.aspx
    Christian
