mx6bfast
Sep 07, 2023Aspirant
New pc hardwired has ip address but not connected to internet AX1750
Just recently bought a new Win 11 pc. It replaced another Win 10 pc that died. Used the same lan cable but the new pc shows it’s connected but no internet. WiFi works but I want to use ethernet so I d...
mx6bfast
Sep 08, 2023Aspirant
I tried that before and it didn't work. I ran it again and still came up with the same solutions, reboot everything. I went back into the router and restarted it again and now the pc connected via ethernet. I didn't make any changes since I rebooted the router yesterday. I don't know but it's working now.
I guess it might be a EAX18. The tab says that in edge and the title bar on the page says AX1750 Mesh Extender.
Thanks for your help.
Kitsap
Sep 08, 2023Master
mx6bfast wrote:I tried that before and it didn't work. I ran it again and still came up with the same solutions, reboot everything. I went back into the router and restarted it again and now the pc connected via ethernet. I didn't make any changes since I rebooted the router yesterday. I don't know but it's working now.
Glad you got it working. Occasionally a network restart in sequence from the outside in is the most effective action. When you do the restart, be sure and pull the power cord for the individual devices and give them plenty of time to complete the boot process. If the device has an on/off button, it does not always do a clean restart.
