mx6bfast
Sep 08, 2023Aspirant
New pc hardwired has ip address but not connected to internet AX1750
Just recently bought a new Win 11 pc. It replaced another Win 10 pc that died. Used the same lan cable but the new pc shows it’s connected but no internet. WiFi works but I want to use ethernet so I d...
mx6bfast
I tried that before and it didn't work. I ran it again and still came up with the same solutions, reboot everything. I went back into the router and restarted it again and now the pc connected via ethernet. I didn't make any changes since I rebooted the router yesterday. I don't know but it's working now.
I guess it might be a EAX18. The tab says that in edge and the title bar on the page says AX1750 Mesh Extender.
Thanks for your help.
michaelkenward
Sep 08, 2023Guru - Experienced User
Look at the label on the thing. It should say Model Number.
Extenders are not the same as routers. They have their own bolt hole around here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In general extenders get their settings through the router they are attached to.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
