FredAloneForEve
Mar 19, 2020Star
New RAX 80 firmware ver: 1.0.2.76_1.0.35
Hey everybody, My router told me this mornig that a new vesrsion was available: 1.0.2.76_1.0.35 The changes: 1. [Bug Fixes] Fixes the issue where the 5G band operates in HT20 but not...
SAM_the_GAM
Mar 20, 2020Luminary
I think the new firmware is regional. I am in Los Angeles, CA USA and I am seeing no new firmware available when I check for update in the GUI. I tried downgrading firmware and upgrading and 1.0.1.70 was the version offered to me.
GabboCH
Mar 20, 2020Apprentice
It was the same with the last firmware release, it wasn't shown on the website for several weeks after the release.
With v70 the nighthawk app found the update but trying through the router web interface said everything was up to date.
Will be interesting to see if people have any better experiences with this version.
The release notes are as useful as always.... :(
Has anyone seen any official posts from Christian_R about this release & if it should fix any of the issues people are reporting?
I'm not sure the items in the release notes really address any of these problems...
- SAM_the_GAMMar 20, 2020Luminary
Just checked the Nighthawk app on my iPad and still no new firmware found
- MacauBBSMar 21, 2020Star
Cannot use the Nighthaw app
Cannot use ReadyCLOUD
Cannot use Time Machine
Now downgraded to V1.0.1.64_1.0.27- Andy4711Apr 12, 2020GuideI have exactly the same problems, downgrading is the solution. POS router continued...
- GabboCHMar 21, 2020ApprenticeI plugged back in my RAX80, did a factory reset & connected with the nighthawk app.
It offered me the update 76 immediately.
Since I'm home, I think I'll try it out as a secondary network to see if a couple of devices can maintain a connection.
I didn't use 70 because it couldn't maintain a LAN connection with my Xbox.
I hope this one is better...- ChocobofarmMar 21, 2020GuideFirmware 2.76 seems to be causing some issues with my LAN connections. Both of my PS4 (which are connected by LAN) are getting disconnected every 3 to 6 hours. Devices connected by wifi don't seem to be affected. Looking at the logs, I see that right after these events the router is reconnecting to the internet and synchronizing it's time with the Netgear server. I know others were having this issue with previous firmware versions, but I wasn't... Will try reverting back to .70.
