scoobycarolannc
Sep 29, 2020Tutor
New RAX120 Firmware 1.0.1.136 is trash I rolled back
I updated the firmware on my RAX120 to 1.0.1.136. What a NIGHTMARE!! All iPhones locked on 2.4ghz. Terribly slow loading of apps & pages. Way more Microsoft Teams drop outs, Sonos Speaker took forever...
Newfiedrool
Oct 02, 2020Virtuoso
Are you saying 60ft is a problem with your connection rate?
RenoT
Oct 15, 2020Aspirant
Stupid question. When you factory reset that means you will need to go to all your IoT devices and connect them one at a time back to your wifi network right? Thanks.
- NewfiedroolOct 15, 2020Virtuoso
If you use the same credentials all your devices should reconnect with no issues. Before resetting make sure you have taken all the details of channel names and passwords then simply setup as before.
sometimes devices can be a bit a of a pain but 99% of the time once you have reset and added all the details the devices will auto join.
- KillhippieOct 17, 2020Prodigy
Yep that's what I do, I just set the SSID and password up as before and all my devices reconnect.
- scoobycarolanncOct 17, 2020Tutor
So I went back and put 1.0.136 back on my router. Still having issues with certain devices getting 30 to 40 feet away and channel hopping. But for no particular reason at all putting it on a second time has given me better overall results I think the only thing left is my problems with Armor and it's VPN occasionally getting jammed.
