scoobycarolannc
Sep 29, 2020Tutor
New RAX120 Firmware 1.0.1.136 is trash I rolled back
I updated the firmware on my RAX120 to 1.0.1.136. What a NIGHTMARE!! All iPhones locked on 2.4ghz. Terribly slow loading of apps & pages. Way more Microsoft Teams drop outs, Sonos Speaker took forever...
nachonighthawk
Oct 21, 2020Guide
since the update a few nights ago... my 2.4G Kasa devices wont connect to the router. I roll the router back to v1.0.1.122 and all works again... and even though i have auto update firmware set as DISABLE.... it keeps updating it to 1.0.2.136 each night.... and then my Kasa devices are offline again.
- KillhippieOct 22, 2020Prodigy
I answered this in the other post, its easier to keep the posts together as this is a different firmware, this is 1.0.1.136 the latest is 1.0.2.136. Make sure you are running the latest firmware as above 1.0.2.136. Use the pinhole at the back and factory reset the router, manually update your settings, do not use a saved config file.
Since this is a security vulnerability like the last update too and we don't know how severe the issue is, stay on current firmware for your safety. If after a full reset you still have issues contact Netgear support if you still have that available or post here,
