scoobycarolannc
Sep 29, 2020Tutor
New RAX120 Firmware 1.0.1.136 is trash I rolled back
I updated the firmware on my RAX120 to 1.0.1.136. What a NIGHTMARE!! All iPhones locked on 2.4ghz. Terribly slow loading of apps & pages. Way more Microsoft Teams drop outs, Sonos Speaker took forever...
Killhippie
Oct 27, 2020Prodigy
Contact Netgear and Kasa and mine did not auto update to 1.0.2.136 but since it seems like a high priority security update better you have it than get your router in some mess due to a vulnerability. Also dont run the router at 160Mhz leave that turned off and if you have connection issues and no AX devices downgrade settings to AC router settings, you wont loose out on much. Also turn off PMF as that can cause connection issues. Have you tried wiping your Kasa devices and reinstalling them? It may be that simple? If they can see the RAX120's 2.4Ghz signal they should be able to coinnect.
nachonighthawk
Nov 11, 2020Guide
I have been using version 1.0.1.122 for weeks now with NO single issue at all with all my 75 connected devices! Care less of their security updates. Godspeed.
- NewfiedroolNov 12, 2020Virtuoso
It's a shame you can't get it to run on the latest firmware. While it might not be important for you some of the security updates really are needed to protect your network.
let's hope when the next firmware is released you can try that but I feel there is something unique your end that is the cause of the issues.
