David1212
Oct 17, 2020Tutor
New RAX200 firmware 1.0.3.102_1.0.56. ???
Netgear may have made a mistake in pushing out firmware 1.0.3.102_1.0.56 for the RAX200 router. This firmware is not listed on the Netgear Support site. This firmware is showing as an download on...
roger1955
Oct 19, 2020Apprentice
Since installing 2 days ago, one issue has arisen: my router quit doing it’s routing thing, no indication via indicator lights on router that there is a problem, Nighthawk App showed router was offline. Powered off the router using power button, then turn back on same way. Everything started working again. Why does this router quit functioning is beyond me......
nr08816
Oct 24, 2020Initiate
I am also seeing similiar issue with the router after upgrade to RAX200 firmware 1.0.3.102_1.0.56. The router works fine for about 2 to 3 days and then suddenly no internet. I have to reboot the router and then everything goes back to normal. I can confirm that I have internet service when I connect directly to my cable modem.
I have also factory reset my router after the firmware upgrade and it is still having this problem.
This seems to be an issue with every firmware version Netgear has released recently.
The last version that I didn't have this problem was 1.0.2.8_1.0.45. But if I go back to this version, I don't have Netgear Armor or Netgear Circle.
When will Netgear fix this permanently?
