David1212
Oct 17, 2020Tutor
New RAX200 firmware 1.0.3.102_1.0.56. ???
Netgear may have made a mistake in pushing out firmware 1.0.3.102_1.0.56 for the RAX200 router. This firmware is not listed on the Netgear Support site. This firmware is showing as an download on...
Therobotman80
Oct 29, 2020Aspirant
Anyone know if the IPv6 is fixed on this new update?
- roger1955Oct 30, 2020ApprenticeIpv6 is good on this f/w
- YousefNov 02, 2020GuideI do have this update, should I downgrade to what in the main website ? For me it's working fine but I am not sure maybe it will create an issue in any time like what happening to the others I was having bad update in previous version and I want a stable update, so what do you suggest ? Keep mine and wait for the next update? Or just download and do downgrade manually from the website?
Last thing I am using ipv4, is there any good benefits of using ipv6 and it's stable in this update and router?- roger1955Nov 02, 2020ApprenticeHi,
I don’t know about which f/w you should use. If things are working for you, just go with the flow. I’m back in the latest myself.
IPV6 is a must for some, and for others, they don’t even know about it. For gaming, it’s recommended. Thanks
