David1212
Oct 17, 2020Tutor
New RAX200 firmware 1.0.3.102_1.0.56. ???
Netgear may have made a mistake in pushing out firmware 1.0.3.102_1.0.56 for the RAX200 router. This firmware is not listed on the Netgear Support site. This firmware is showing as an download on...
barein56
Apr 13, 2021Aspirant
I would throw a gigabit ethernet switch among the MR1100 and the Ubiquiti, simply so you could have additional LAN ports. If you get a gigabit ethernet switch with Power over Ethernet (PoE) and in case your Ubiquiti supports PoE, you may keep the more power outlet.
