mattocaster
Jun 17, 2019Guide
New Rax80 MAJOR Problems!!
Hi! Just bouth the new Rax80 and set it up this friday with latest software. I have major problems. The Iphones loses internet, they detect the network and have full coverage but internet doesn't wor...
mattocaster
Jun 18, 2019Guide
Hi! I have 1.0.1.58 installed. I have reseted to factory default and have to wait and see how it turns out.
michaelkenward
Jun 18, 2019Guru - Experienced User
Good luck.
If it does not work, out, come back with detailed descriptions of those "problems".
- mattocasterJun 18, 2019GuideOk that didn’t work at all. What do i do now? A restore didn’t work. What happens is that wireless network Lise internet. I can connect all devices wireless with full network connection but Internet is dead, can’t egen connect to the Netgear App!
- michaelkenwardJun 18, 2019Guru - Experienced User
Did you ever mention the modem in the network?
- mattocasterJun 18, 2019GuideI have the Rax80 connected to fiber on the wall, is that box the modem? Before i used a Time Capsule and never had a problem, only bad range. The problem must be the router, the Rax80. The network seems to work and i can connect without problem, but the problem seems to be that it can’t transfer wireless data, internet don’t work and my Netgear iPhone App can’t connect to the router. Somriges it work but mostly not as IF right now. Have to get this working or else i have to returen the router and but something else.
