mattocaster
Jun 17, 2019Guide
New Rax80 MAJOR Problems!!
Hi! Just bouth the new Rax80 and set it up this friday with latest software. I have major problems. The Iphones loses internet, they detect the network and have full coverage but internet doesn't wor...
Ahkim2000
Aug 22, 2019Aspirant
Are you using the smart WiFi feature? If so, turn it off. Rename your WiFi connections separately 2.4 and 5ghz respectively. Finally, connect your iPhones to the 5ghz WiFi channel. I’m not sure why but iPhones will not stay connected to the 2.4 ghz channel. Even though 2.4 is recommended for non-stationery WiFi devices.
