mattocaster
Jun 17, 2019Guide
New Rax80 MAJOR Problems!!
Hi! Just bouth the new Rax80 and set it up this friday with latest software. I have major problems. The Iphones loses internet, they detect the network and have full coverage but internet doesn't wor...
BigDonny
Sep 14, 2019Initiate
I need some help here on this. I have the same problem with my router. The WiFi crapped out. I can't even log into the router as it times out. This just started 2 days ago. The router functions on the wired Ethernet side only, as that is how I'm able to submit this response. I just updated the latest firmware in the past month or so and I don't recall what version it is. I can ping the router, but like I said I can't get into the GUI to do anything. Pressing the WiFi button on the top of the unit does nothing. I've had this thing maybe 6 months, I can't beleive that it crapped out already.
Thoughts???
PirateGee
Oct 13, 2019Initiate
Problems is Right! Paying Beta Testers huh? my first issue was \\Readyshare devices after my 3rd solution I completely lost internet, just after removing all the windows updates from the past 48 hours. Reinstalled the updates with the new router in place not old that seem to resolve the USB devices in Readyshare able to map network drive now. Next I could not get see the device nor the wifi on. I found that I have an Intel 7260 wifi that shuts of wifi intermittenly with the latest driver version 18.x. I did a roll back to 17.x and It's working great now. If I get a couple days stable then I'm happy, good luck.
