mattocaster
Jun 17, 2019Guide
New Rax80 MAJOR Problems!!
Hi! Just bouth the new Rax80 and set it up this friday with latest software. I have major problems. The Iphones loses internet, they detect the network and have full coverage but internet doesn't wor...
namatta
May 26, 2020Aspirant
I had major problems for a few weeks. I almost gave up and returne dthe router and extender. I finakly was able to set it up with settings that work really well...so well that I bought a second extender to give coverage to my garage. Here's what worked for me in the advanced settings:
Check "Enable implicit beamforming..."
Check "Enable MU-MIMO"
Uncheck "Enable AX..."
Unchecking enable AX was not what I had hoped for. But, it fixed my problems.
mjc775
May 28, 2020Luminary
namatta wrote:I had major problems for a few weeks. I almost gave up and returne dthe router and extender. I finakly was able to set it up with settings that work really well...so well that I bought a second extender to give coverage to my garage. Here's what worked for me in the advanced settings:
What firmware version are you using? What were the problems that you were experiencing?
- depaulaJul 11, 2020Initiate
i too have a neatgear rax80 router. it is also fairly new. it has now stopped working. it looks like it is ok, but no internet. i confirmed that the fios is working. i reset the rax80 and still no internet over wifi. i reset it several times. i unplugged it overnight and reset it. it does not work. i plugged in my old router and it works great. (not a neatgear). I have had problems with this router in the past. very troublsome router. i will not purchase neatgear again.
