mattocaster
Jun 17, 2019Guide
New Rax80 MAJOR Problems!!
Hi! Just bouth the new Rax80 and set it up this friday with latest software. I have major problems. The Iphones loses internet, they detect the network and have full coverage but internet doesn't wor...
wcotthi602
Jul 20, 2020Aspirant
There is nothing worse thatn spending the money to buy a new expensive device then having to spend all your time troubleshooting problems when the manufacturer could have done better quality testing to solve the problems before putting it on the market. I love electronics!
michaelkenward
Jul 20, 2020Guru - Experienced User
This is particularly true of new technologies. They need extra care and extensive testing. Sadly, the reports of the RAX range are universally poor on that front.
This really is a case of sitting in your hands until they have sorted things out. It isn't called bleeding edge technology for nothing.
- jimmy69Jul 21, 2020Aspirant
I want to return this router. I've tried a dozen combinations of settings and it still drops connections.
- michaelkenwardJul 21, 2020Guru - Experienced User
As this is your first message – welcome to the funny farm – we don't know what, if anything you have tried to fix it. If you do want help, you'd do better to start with a new question. That way people won't get confused by the past stuff, and the Netgear crew may be more likely to spot.
If this is a new purchase, you can also ask for help from Netgear in the usual way.
Contact Us | Support | NETGEAR
