bschmut
Nov 13, 2022Aspirant
New RAXE500 not allowing cable box to work
I have a new RAXE500 just setup. My Altafiber Encore cable box is connected direct to it via ethernet cable. On my previous router, RAX50, I had to check Disable PMF in the advanced wireless settings...
Nov 13, 2022Guru - Experienced User
What is the model# of this cable modem?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- bschmutNov 13, 2022Aspirant
What is the model# of this cable modem? 455m-CBT
What Firmware version is currently loaded? v1.0.10.86
Like I said previously, everything worked with the RAX50 I just stopped using. Just had to check Disable PFM. The new RAXE500 does not have that option.
Have done all resets, reboots, etc in every way and order possible.
- FURRYe38Nov 13, 2022Guru - Experienced User
Not sure if this model router supports that feature. Thats a wifi mostly feature I believe. Should not effect WAN to LAN connection with the ISP modem or ONT.
