xfire04
Mar 11, 2020Aspirant
New router issues with Netgear CM1000 modem.
I have Cox internet with a Netgear CM1000 modem but have problems with all WiFi 6 routers I have tried and had to return them for locking up or dropping signals. I have tried both Netgear and Link...
Mar 12, 2020Guru - Experienced User
xfire04 wrote:I have Cox internet with a Netgear CM1000 modem but have problems with all WiFi 6 routers I have tried and had to return them for locking up or dropping signals. I have tried both Netgear and Linksys. I also have a hub plugged in for extra wired devices.-----hopefully going modem------router-----switch? Ortherwise if you're going modem------switch-----router, that'd be your issue. I have 300mbs service, Any ideas or has anyone else had similar problems? Cox says signal is great.------that's their default response. you can log into the cm1000 and get a screen snip of your modem connections page and your logs. These help determine signal stregth/quality. Again, Cox is going to say its fine because otherwise it costs $ for them to send someone out. I uses the latest firmware all all routers.
xfire04
Mar 12, 2020Aspirant
How do I log into the CM1000?
