thrt443
May 28, 2024Aspirant
New router netgear nighthawk rax50
Setup new router from my PC, keep asking for Netgear user/pw. I entered my Netgear userid/pw then error popup "Something is wrong. Try again". Keep trying still same error. Then it said continue to se...
thrt443
Yes, I finally did. However, after rebooting my PC, problem appears again, can't log into the router. Internet is fine, just can't log on to the router.
And yes, it happened after I updated to latest firmware. Even after reset router, the new firmware is still there.
So now, If I want to keep this router, I have to re-setup every time I want to login to the router, as there seems to be no solution and support is non-existence.
May 28, 2024Guru - Experienced User
Did you factory reset then setup from scratch while off line then setup and complete the setup, then connect the router to the ISP service?
What FW version do you have loaded?
Do you have a v1 or v2 model router? I have a v2 and have been able to get access aftre the first time I reset line and got back in after I reconnected it to the ISP service.
How long have you had the router?
- thrt443May 28, 2024Aspirant
yes, I did the factory reset. then disconnect from modem. then re-setup in edge.
it was fine. Then I reboot my PC and tried to logon to the router and problem appeared again.
The firmware is 1.1.4.28. why was it still there even after I factory reset?
Is there away to rollback to previous firmware?
mine is RAX50v2. I just got it last week and setup yesterday. It was quick ... until i did firmware update.
You mean, if you reboot your PC, or turn off/on the router, you still can log back in?
