Conan63
Dec 21, 2021Follower
New router won't connect to the internet
I am in the position of not knowing what I don’t know, hence my request for guidance here. I have CenturyLink fiber internet (1 mbps) service at my home. The modem provided by CenturyLink is a nond...
Dec 22, 2021Guru - Experienced User
I recommend you contact your ISP to have them help you with the serivces and configuration of the PPPoE. There maybe some settings needed. Make sure you can replaced there router with your router.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
