RouterBeast22
Jan 19, 2025Aspirant
New TCL Google TV will not connect to internet thru my AX5-RAX43 WiFi Router
I just purchased a TCL 65" Google TV from Best Buy. After trying to connect the TV to my WiFi and failing, I reached out to TCL Support. I confirmed with TCL Support that my WiFi signal strength was...
Jan 19, 2025Guru - Experienced User
- RouterBeast22Jan 19, 2025Aspirant
Thank you for your response.
There is no ISP provided Modem.
My Netgear Nighthawk AX5 is connected by a CAT5 cable coming from the outlet in the wall that the ISP installed.
The AX5 WiFi router is not a cable router,
There is no Coaxial cable connector on the back of the WiFi router.
- michaelkenwardJan 20, 2025Guru - Experienced User
Connecting a TV to the network is usually best done through the TV's controls and set up routine. The router rarely does much more than spit out the wifi signal. It is then down to the TV to do its thing.
Where possible, it is usually easier to use a wired connection from the router to the TV. It is easier to set up and less likely to fall over. If you can't run Ethernet cables around the place, you could look into Powerline Ethernet. It turns your mains wiring into an Ethernet circuit.
The source of the Internet is probably less important than the brand of the TV. Same are easier to set up than others. You could try a search around here of your TV.
For example:
Search - NETGEAR Communities – Samsung TV
And:
Search - NETGEAR Communities – "Google TV"
Just another user with time on their hands.
