Jamiemc24
Dec 07, 2023Guide
New Virgin Media Hub 5 and AX1800 NG problems
Hey everyone I recieved the new virgin media hub 5 (I previously had the 3) it’s connected via Ethernet to my NG router upstairs but now my NG router seems to give no wireless signal? Everything hardw...
Dec 07, 2023Guru - Experienced User
Between the RAX and the host router yes.
Jamiemc24
Dec 07, 2023Guide
Thank you so much for all your help! I’ll do this tomorrow when I’m up - will I need to factory reset my NG again to set up AP or is it quite straightforward?
- FURRYe38Dec 07, 2023Guru - Experienced User
No FR needed.
- Jamiemc24Dec 07, 2023GuideI ended up doing what you said changing SSID and Password to both the router details and it’s fixed all my problems. Thank you so much guys for your amazing help and sorry for being a bit full on coming into the forums - appreciate you all so much and have a fantastic Xmas.
