rtylerk
Mar 26, 2021Aspirant
Newly purchased RAX75/DOS Attacks immediately upon connection as well as...
Hello - So I just got my router yesterday and it wasnt hard to set up but once i started accessing it via the web GUI, I noticed there were some wierd things happening.. For example: I confi...
Christian_R
Mar 26, 2021NETGEAR Employee Retired
Hello rtylerk,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
rtylerk
Ok. yeah I did that right after my post here, just thought i would get all the feedback i can.
Thank you.
