rtylerk
Mar 26, 2021Aspirant
Newly purchased RAX75/DOS Attacks immediately upon connection as well as...
Hello - So I just got my router yesterday and it wasnt hard to set up but once i started accessing it via the web GUI, I noticed there were some wierd things happening.. For example: I confi...
antinode
Mar 26, 2021Guru
> [...] I was receving DOS attacks from the same 2 I.P's. [...]
Which kind(s) of "DOS attacks" from _which_ IP addresses?
> [...] I also found an embedded XML file viewable from a wan software
> interface [...]
I don't know what that means. How, exactly, are you viewing this
thing?
> [...] The XML is referring to WAN side uPNP [...]
The fact that text like "WAN" appears someplace in this thing does
not mean that the WAN/Internet port on your router is involved.
Certainly, "192.168.1.1" does not suggest "WAN/Internet" to me.
> [...] I cant un-tick the "Ping Internet Port" to disable it..
Do you mean ADVANCED > Setup > WAN Setup : Respond to Ping on
Internet Port? "ping" uses ICMP, and is unrelated to anything like
HTTP. That option should do what it says that it does, which seems to
be unrelated to whatever you expect it to do.
