DSteiny18
Sep 04, 2019Follower
Night Hawk ax4 won't do wired and wireless at the same time
My brand new Night Hawk AX4 router will not do wired internet at all, and when I plug the CAT6 cables into the back of the router, the wireless internet stops working. I have already restarted the ro...
camping147
Sep 04, 2019Guide
What have you plugged into the router? Is there another router that would cause IP issues with more than one DHCP address being assigned?
michaelkenward
Sep 05, 2019Guru - Experienced User
Excellent questions. On the same tack, what modem, if any, sits in front of the router?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
