muniba15's avatar
muniba15
Follower
Oct 19, 2019
Night Hawk RAX120 Parental control option missing
Hi, I am unable to see parental control option on my routerlogin.net or mobile app. Any help?
  • plemans's avatar
    I couldn't find anywhere that the rax120 supports parental controls. I also couldn't find any info on disney circle for  the rax120. I don't have a rax120 to log into to check this but neither the manual, spec sheet, or advertising had parental controls listed that I could find.
  • I just set mine up a couple of days ago and found the same thing. Apparently there are no parental controls with the RAX120. I'd like to see it added, even if it's Circle.
  • Will the Rax120 eventually have Disney Circle like the other netgear routers?
    • plemans's avatar
      I'm not a netgear employee but my bet would be on yes.  Again, not an employee and this is just a guess as they've rolled it out for older routers and integrated armor in other routers. It seems like between armor and disney circle, a reliabe revenue stream for netgear/bitdefender/disney.
      good thing with it not being rolled out yet is that it means they're focusing on getting the RAX devices running well before adding features/complexity.
