kshaq's avatar
kshaq
Follower
Apr 20, 2021
Night Hawk RAX200 wireless router
I have a Night Hawk Netgear RAX200 wireless router that I purchased in November of 2019.
This wirelss router was working fine and then the Wifi stopped working suddenly.
The router connects to the internet through a modem provided by Spectrum.
The router connects fine to the internet but the wifi is not working.
None of my wireless devices would connect to the wireless router wifi.
I have trouble shooted everything multiple times.
I have rebooted the wirelss router and the modem several times.
I have checked for any firmware update which the wireless rourter does not require.
I can connect to the router remotely.
I cannot make the wifi work !!
The wifi of the router will not work !!
Any suggestions from the community ?
1 Reply
  • plemans's avatar
    Is the wifi broadcasting?
    Can you see it and when you try to connect it says "connected, no internet"
    Are the wifi led's on?
    Did the wifi on/off buttong get hit? Push and hold it for 2 seconds.
