snowlapa
Mar 27, 2025Follower
Night Hawk RAX50 NordVPN / OpenVPN Ready
Hi All, Just as the subject says, is the Night Hawk RAX50 NordVPN / OpenVPN Ready? One more question, having the RAX50, would upgrading to a Wi-Fi 7 Router gain me any benefit? Thank you, Fra...
michaelkenward
Mar 27, 2025Guru - Experienced User
Have you asked NordVPN? It should have a list of devices that work.
NordVPN lets you use the Internet while hiding your presence and what you are up to.
OpenVPN has a different role. It is there "to remotely access your router using virtual private networking".
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual InstallOpenVPNSoftware
Just another user with time on their hands.
