ABC12345a
Dec 16, 2022Follower
Night hawk rax78 reset
lost my WIFI name internet after router reset. now its default to netgear. How do I fix this?
michaelkenward
Dec 17, 2022Guru - Experienced User
ABC12345a wrote:
How do I fix this?
If you mean, how do you get back to the SSID (wifi name) from before the reset:
How do I change the WiFi password or security level on my NETGEAR router? | Answer | NETGEAR Support
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
Then there is the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
