MikeReilly
Feb 19, 2023Follower
Night Hawk Router RAX120v2
Purchased the above referenced router approximately 5 months ago as a replacement to an older Netgear Router. Set up was easy however since install, this router continually reboots without cause. This certainly causes challenges when working or streaming. I updated the firmware but this did not resolve issue.
To date I have yet to hear the internal router fan turn on, any ideas would be helpful. I have exclusively used netgear products over the 10 plus years, perhaps time to go to a different brand?
I appreciate any feedback.
Thank you
1 Reply
Visit the section where they talk about these RAX devices and you may find useful conversations.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
