JimTheGreek
Jun 19, 2020Tutor
Night hawk unable to connect to RAX80
It all started w/my iphone would not see HP printer, out of the blue, even though the printer showed an IP in my network and said all ok AND nighthawk showed it on the network, WITH the right IP. Af...
- Jun 24, 2020
Sorry, I should've reported back. I finnaly got it, this is what I had to do, I did not want to go thru factory reset....
Powered down router, unplugged everything from it, including to the modem.
Then, I plugged in the modem only, at that point & forward I was able to connect to the router.
It seems there was some glitch w/it. It had lost connectivity w/two devices (that I know of), one wired and one wireless, and of course access to admin router; both wired AND wireless!
But once I plugged everything in, everything was back and I'm back in business!
Very interesting AND frustrating experience!
Thank you for the reply and I apologize for not reporting back in a timely manner!
Cheers!
JimTheGreek
Jun 19, 2020Tutor
Sorry, allow me to add, printer still not connecting to anything. Even though it shows the new IP that is within my network. Again, internet/wifi is working fine on all devices, except printer (least of my worries for now), I can even ping the RAX80 (of course, since I have connectivity), but had to check that for the hell of it!
Just a few minutes ago, my family said, TV has not netword, and sure enough, it doens't.
I power cycled it, still no good, switched to wifi, up and running fine.
What the heck is going on? Is the RAX80 acting up or am I missing something?
- Christian_RJun 24, 2020NETGEAR Employee Retired
Hi Jim,
I would suggest running through a factory reset on the router and going through the setup assist assistant again.
Christian
- JimTheGreekJun 24, 2020Tutor
Cheers!
