miclin
Jan 03, 2021Aspirant
Nightawk AX8 AX6000 WiFi router cannot connect always
Hi, I always cannot connect my wifi router, e.g. I chose 5GHz network, can use WhatsApp only but I browsed website not successful, then I turned to 2.4GHz can use a while, but browsed other page then...
miclin
What modem/gateway do you have?
RAX80 AX6000
What firmware is on the RAX?
V1.0.3.106
Does this always happen?
Yes
Is it only happening on 1 device or all devices?
All devices
Does it happen to devices that are hardwired in?
No, problem in all devices included iPhone, iPad, Apple TV and Xbox
RAX80 AX6000
V1.0.3.106
Yes
All devices
Jan 03, 2021Guru - Experienced User
The RAX is the router. what modem/gateway is it connected to?
Have you tried a factory reset and a clean install?
