satender346
Jun 21, 2023Aspirant
Nightawk RAX40 AX3000 AP ( Access Point ) mode not working
"I have AT&T as my primary router and I recently purchased the RAX40 (AX3000) router, which is functioning normally and able to access the internet. However, when I enable AP mode from the settings m...
satender346
Jun 22, 2023Aspirant
I did power cycle both the ATT router and Netgear router, it is not helping. Also I tried AP mode without internet wire connect ( Local LAN ) but getting same issue, After applying AP mode, router restarts and become unidentifed network and no longer accessible.
michaelkenward
Jun 23, 2023Guru - Experienced User
What do you mean by becomes "unidentifed network"?
Is there a wifi SSID of some sort visible to Wifi clients?
As to no longer accessible, how are you trying to access it?
As I already explained, in AP mode you can't access the browser graphical user interface (GUI) on the RAX40 without a bit of effort. Certainly don't think of using routerlogin.net. If that gets you anywhere it should be the main router.
You have to track down the IP address that your main router has allocated to the RAX40.
We don't know the make and model of your primary router, but somewhere in its GUI you should be able to find a page that lists Attached Devices. One of those devuces will be the RAX40.
In the case of my R7800 in AP mode connected to a MR router, is a wired Attached Device.
