Jpoiss89
Aug 25, 2021Initiate
Nightawk RAX70 troubleshooting
Hello there, Setup information: - ISP Telus (Canada-AB) - Modem T3200M (Modem/Router combo) - Nightawk RAX70 This is my last resource and attempt at resolvinf my issue before I send back the ro...
Aug 26, 2021Guru - Experienced User
double nat can cause issues.
How to fix issues with Double NAT | Answer | NETGEAR Support
You can try the t3200m in passthrough/modem only mode.
Or you could try the RAX in access point mode.
Jpoiss89
Aug 26, 2021Initiate
Thank you Plemans for the reply. I was able to fix my problem.
I first tried to set the T3200M in bride mode, rebooted both the modem and the router. That didnt worked. I also tried again with a fresh installation on the Rax70. That didnt worked.
Now for trying to set the RAX70 to access point (AP)... Even with a hardwire connection to the rax70, I was still unable to access the router admin page with either routerlogin.net, routerlogin.com or 192.168.1.1. My credentials had been reset and were simply not working for some reason.
Solution:
I then completly removed the T3200M, plugged the RAX70 to the ONT box and did a factory reset/fresh installation. I was now able to access the admin page and my WIFi/internet available to all my devices without the need for the T3200M modem.
Hopefully someone with a similar issue will find that useful.
Thanks!
Solution:
Thanks!
- plemansAug 26, 2021Guru - Experienced User
Glad it worked for you.
when you're in AP mode, the t3200 would have assigned and IP address. You'd have had to look in its attached devices page (or equivelent) and found the IP address.
but you've got it working so good work!
