Andy73
Jun 26, 2020Aspirant
Nighthawk® AX12 12-Stream WiFi 6 Router (RAX120) bt iptv setup
i have the bt openreach modem (fttp) .i am trying to set up the netgear Nighthawk® AX12 12-Stream WiFi 6 Router (RAX120) to work with the bt iptv channels like bt sport etc on my bt youview box . it ...
Newfiedrool
Jun 27, 2020Virtuoso
under wan settings Untick Disable IGMP proxying and click support BT and see if that helps.
- Andy73Jun 28, 2020Aspirant
hi , done that last night and bt sport channels etc came on .when i got up this morning it had stopped working again, i unplugged the bt youview box and power it back up and it still did not work . i then restarted the router and the channels came back on again . is there some other setting i have to change so the same thing does not happen tomorrow morning .
thanks .
