bcuziwasbored
Apr 08, 2020Aspirant
Nighthawk® AX12 RAX120 5GHz Issues
I just got the RAX120, but when I went to set it up, I found that I can't see the 5GHz band from any of my devices. I have multiple devices which support WiFi 6, but they can't see it either. I've ch...
- Apr 10, 2020Amazon Warehouse got another unit last night. I'm just going to get a replacement. Thanks for your help though!
Christian_R
Apr 10, 2020NETGEAR Employee Retired
Hello bcuziwasbored,
Would you mind performing a factory reset to see if that would help. You may also try to get in contact with our support team as newly purchased devices are provided with complimentary support.
https://www.netgear.com/support/default.aspx
Christian
bcuziwasbored
Apr 10, 2020Aspirant
I factory reset it twice, but that didn't make a difference. I got it from Amazon warehouse, so it's basically refurbished. It was previously linked to someone else's account, so the 90 days is support has ended.
